Old 1-Nov-2010, 9:32 PM   #14
No static at all
No static at all's Avatar
Originally Posted by mazy View Post
(1) does antenna need any horizontal tilting ?
A slight tilt upward can improve reliability of problem stations, especially if you have hills in the way. I usually end up using the first notch of the tilt mechanism.
(2) can i get FM signal from these antennas? Originally, I wasnt thinking too much about FM ; mainly wanted TV signal. Hopefullly this set up will overcome the hills in my area.
Neither of the antennas are very good with FM, which is actually a plus for you since your TV stations are on the weak side. If you desire FM, I would suggest an inexpensive FM only antenna with a separate cable run to the receiver from the antenna. You will generally get the best results if you keep TV & FM separate in weak signal areas.
