Old 23-Aug-2013, 5:33 PM   #2
Stereocraig
Originally Posted by serengety View Post
Hi all.
I have a bit of a problem. I found an antenna that MIGHT be interesting but I don't really know.
What they say is "This VHS/UHF/FM/TV antenna with built-in high gain amplifier (up to 15 to 18 dB) delivers amazing picture quality and has a remote to help you position it! You'll enjoy clear images from even distant or weak stations. Also has 45-860 MHz operation frequency and 75 ohms output impedance. It's crafted from weather-resistant ABS and aluminum and mounts in just minutes. Plus it comes with a high powered receiving booster, low noise microwave amplifier tube for enhanced resolution, 360 degree rotation and more. Receives channels 2-69 and operates up to 2 tv's."
Now, I do understand a little bit of that, but most of it goes over my head. Is this combo good, bad or indifferent? It is supposed to have a 100 mile range.
You will only have a problem, if you buy it.
Those are flimsy garbage and the claims are ridiculous.
Post your TVFOOL report and somebody will be able to make a sensible recommendation.
