			Thanks for posting the second TVFR. The signals from the northwest are significantly improved.
If reliable reception of the signals from the Sutro Tower complex are a priority, I would definitely recommend mounting outdoors. A Winegard HD7694P would have both UHF and High-VHF capability. Aimed at about 310° per a compass, you should expect reception from both major groups of signals. This assumes you actually mount outdoors at about 25' AGL, clear of major obstructions such as vegetation and buildings.
I would not expect the CS4 to reliably receive KGO or KNTV.
						Reason: CS4 - KGO - KNTV
