You can certainly try mounting in the attic... That will reduce your reception, how much is dependent on the attic and roof construction.
The CS4 is an excellent UHF antenna. But you have several VHF signals to consider also.
Each of the station call sign listed on a TV Fool report is an active link to a profile for that station. Click on any of the stations transmitting from the Sutro tower and you'll see that you are very close to having a direct line of sight to those signals... Can you generate a second TV Fool report using 25' as the antenna height?
It would be great to see the TVFR for the added height before making a specific recommendation.
