Old 22-Aug-2013, 9:23 PM   #2
Given that you already own the VU-190... OK, try it. It's much larger than needed in your application.
You may get away with using a distribution amplifier, but with the very strong signal levels, if you have not bought one yet, save your money. An amplifier of any type is likely to cause trouble by being overloaded. If that happens you'll have less, not more reliable reception.
Given the information in your TVFR, I would point an RCA ANT-751 due north, no rotator, no amplifier, and expect to have plenty of power to drive a passive 4-way or even 8-way splitter.
