Old 22-Aug-2013, 8:34 PM   #1
Ih8cable
Question Seeking OTA Set-up Advice
Hi Guys!
I have finally decided to unplug from the crappy (& expensive) U-worst! I have a old but unused Radio Shack VU-190XR UHF/VHF/FM antenna & a new Channel Master CM-9521A Rotator. I was planning to roof mount (at about 25 feet?) the antenna and feed through a Winegard HDA-200 distributor amp to my 4 tvs and FM stereo.
I was told by the local Radio Shack manager that the antenna should be fine for HD even though it's an old model. But before I install I thought I'd make sure I'm doing this right. So, maybe I could get some feedback on this. Is this antenna /setup adequate for bringing in the maximum amount of channels in my area? The VU-190XR outdoor HDTV-ready antenna has a range of 100 miles FM & UHF and 190 miles VHF. It has a 160-inch boom length and 95-inch width and a 38-inch height and is generally used in green CEA zones.
Second, Am I able to feed my FM stereo through the Winegard HAD-200?
Any other tips regarding setting this up would be much appreciated!
Thank you!
John of San Diego, California
http://www.tvfool.com/?option=com_wr...46ae058fc7957e
Ih8cable is offline   Reply With Quote
