Old 22-Aug-2013, 7:34 PM   #3
fischerms80
I have tried the 2 antennas with combinations of amplifiers hooked to each antenna or not. Very hit & miss, sometimes monoprice antenna w/ amp & moho w/o amp will work, other times would have to pwer up the mohu. Noting is consistent. Pretty have given up on KIRO 7 over the air with ther nighttime issues.
Originally Posted by teleview View Post
As always , combining dissimler antennas with a reversed splitter in a random way , produces bad reception.
Connecting antenna system amplifiers / distribution amplifiers and amplified antennas in a random way produces bad reception.
Disconnect and Remove All of the antennas and amplifiers.
_____________
Recommend install a , --> Antennas Direct - Clear Stream 2 Complete Uhf/Vhf antenna <-- , in/at the window aimed at about 72 degree magnetic compass direction.
CS2 Complete Uhf/Vhf antenna at Amazon. C2-V-CJM .
______________________
For 4 Tv's connected use a simple common 4 way splitter.
Test reception Without a antenna system amplifier.
If a antenna system amplifier is required , use a , Winegard LNA-100 'Boost' antenna system amplifier.
_________________________________________
http://www.solidsignal.com.
http://www.amazon.com.
http://www.antennasdirect.com.
fischerms80 is offline   Reply With Quote
