Old 21-Aug-2013, 12:07 AM   #1
olnick
Red face Back to OTA signals
Its been a number of years since doing any antenna setups. I got rid of money bags AKA directTV and want to be self reliant! My problem is there are a bunch of stations in the Boston area that I should be able to receive. Living in Milford NH I also like the local news from Manchester NH. I don't want to use a rotor, my thoughts are to use two antennas pointing one in each of the desired directions. I plan to use an RCA ANT3036X to pick up the Boston stations. How good would this antenna be picking up from the side? Antenna #2 I'm open to suggestions. What would be the best way to combine the signals? I do have a sladco min/max signal strength meter to check the signals from the different stations. What should I look for strength min to max to have a balanced system?
Ill be installing the ANT3036X at the top of the 10 foot mast mounted to my chimney, What is the recommended spacing for additional antennas on the same mast? Signal results are at below link
http://www.tvfool.com/?option=com_wr...46ae263716079c
olnick is offline   Reply With Quote
