Thread: Indoor Antenna:
Old 19-Aug-2013, 7:55 PM   #11
Here is how aim indoor and outdoor type antennas , http://www.kyes.com/antenna/pointing/pointing.html.
As recommended use the HDTVi antenna or the CS2v Complete Uhf/Vhf antenna.
The Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some Digital Tv's will Automatic channel scan for cable tv channels.
Go into the Tv Setup Menu and select , 'Air Channels' ~ 'Antenna Channels'.
Scan for channels.
