Old 19-Aug-2013, 7:30 PM   #3
Bad connections and bad coax are the first situations to check.
Water damage of connections , water damaged coax.
The coax and connections can look good and still be bad.
As a Test.
Run a continues length of NEW coax that has the compression type connectors , not the old crip type connectors , through a open door or window , direct to one Tv.
_________
Tvfool shows the Real channels that are transmitted and received , and the , virtual numbers.
KQED Real UHF Digital channel 30 , virtual number (9.1) , PBS .
