You can find a small amount of directional behavior with just about all the 'omnidirectional' antenna designs. Try rotating in 10° increments...
Also, closely inspect for moisture in connectors or physical damage to the the coax, including sharp bends or crushing. These can cause problems that seem to affect only one or a few channels. If in doubt, try a new piece of coax (one of the least expensive test tools you can have). Coax-Seal or Scotch brand # 2228 Sealing tape is recommended on any connection exposed to the weather.
