Old 19-Aug-2013, 5:25 AM   #15
Aaaahhhhh...
The CMCDT2106T-HEP is a directional tap, not a splitter. http://www.antronix.net/Products/cat...oppassives&i=8
If you switch to a CM-3412, you would need to run more cable or locate the amplifier at the present location of the tap. That would either cost time and money or reduce the benefit of locating the amp where it can overcome all the system losses. I would stop by Home Depot and buy an Ideal #85-132 2-way splitter for less than $4.
Also, be absolutely certain that the power coax is connected only to the 'PWR IN' port on the CM-3410, not the 'PWR IN / RF OUT' port. You need to be sure the power line does not feed power into the splitter or TV tuners.
Last edited by GroundUrMast; 19-Aug-2013 at 5:41 AM. Reason: commentary re. amp location, sp.
