Old 19-Aug-2013, 2:05 AM   #12
Jeremiah
No need to buy another splitter... the splitter built into the CM-3412, 3414 & 3418 are no improvement over the existing passive splitter you already have. The amplifier is the same in each of those models as that used in the 3410.
Well, that was all a spectacular failure.
Ran about 75 ft of coax in the attic from a power outlet to the amp. Used the included 6 ft of coax to run the amp to the antenna itself, then connected the TV line.
Everything worked great until I attached the second line to the splitter in the basement. First line plummeted from 18 channels to 3. Second could not pick up anything. Now I am at a loss and am wondering what to do.
I know you said I don't need another splitter, but should I purchase the CM-3412 instead? Is there another way?
Jeremiah is offline   Reply With Quote
