Old 19-Aug-2013, 2:04 AM   #3
elmo
In your situation, an effective antenna does not need to be big or expensive.
An RCA ANT-751R or Antennacraft HBU-11 pointed SW should give you very good results.
Signal splitters and the coax cable can be re-used. Be sure to remove satellite system parts that will block over the air TV signal frequencies.
Don't you mean pointed SE?
