Old 18-Aug-2013, 6:42 PM   #2
In your situation, an effective antenna does not need to be big or expensive.
An RCA ANT-751R or Antennacraft HBU-11 pointed SW should give you very good results.
Signal splitters and the coax cable can be re-used. Be sure to remove satellite system parts that will block over the air TV signal frequencies.
