Old 17-Aug-2013, 11:06 PM   #6
Aim the ANT751 at about 318 degree magnetic compass direction.
Use a Old School magnetic compass.
Install a Winegard , LNA-100 'Boost' amplifier.
Install the LNA-100 in the coax line between the antenna and splitter.
The Best Practice is to install a amplifier before any signal losses that occure after splitters.
The Best Practice is to install a amplifier before any signal losses of long lengths of coax.
Reason: amplifier 'Do Not Pull Signal' through splitters and 'Do Not Pull Signal' through coax and amplifiers 'Do Not Pull signal from antennas'.
Amplifiers , Amplify and 'Push Signal' through coax and splitters.
_______________________
The ANT751 is a small antenna.
Small antennas receive less signal.
Bigger antennas receive more signal.
Receiving more signal means more signal strength will be in the system from the start.
More signal strength at the start is the best.
