Old 17-Aug-2013, 8:53 PM   #3
Your reception location has recivable Tv stations the directions of , North , North East , South West , South.
Above the roof in such a manner that the roof and house are not impeding and blocking reception in the directions of , North , North East , South East , South.
Install a Channel Master CM5016 antenna aimed at about 14 degree magnetic compass direction.
Use a Old School magnetic compass.
A Winegard , DS3000 J pole type antenna mount will work well with the CM5016 antenna.
___________________________
A metal roof Will Reduce and Block Tv reception with antenna in attic.
A antenna system amplifier will most likely Not Be required for reception.
Yes , reception can be 'tested' with a antenna system amplifier connected between the antenna and splitter.
Use a Winegard , LNA-100 'Boost' antenna system amplifier.
_________________________________
http://www.solidsignal.com.
http://www.amazon.com.
________________
