Old 1-Nov-2010, 9:36 AM   #2
John Candle
Tv Reception
I recommend the Winegard HD7695P antenna and a rotator. The Channel master CM9521A rotator or the http://forum.tvfool.com/showthread.php?t=460 . http://www.solidsignal.com . If the tv has a built in broadcast digital tuner then will not need a digital to analog tuner. The antenna is a big antenna , needs a Strong mount. The tripod type roof mounts are strong mounts. Chimney mounts are strong mounts.
