Where to amplify
I just installed an Antenna at my parents home. I mounted on the chimney and and ran the coax cable to a three way splitter. Two tv's connect to the splitter with a fairly short run and receive all channels pretty strong. The third tv is located pretty far from the splitter and is not receiving all the channels due to a weak signal I believe from the long run. Should I install an amplifier after the splitter for this tv. Any advice on where the amplifier should be and a recommendation of a brand and model would be appreciated. The installed antenna is a RCA ANT751.
Thanks
