Old 17-Aug-2013, 7:15 PM   #1
bsp
Strange reception problem
I have a reception problem that doesn't seem to make any sense to me so I'm hoping someone else here might have some suggestions about what is wrong.
I live in a valley about 35 miles north of a couple of HDTV transmitters. They're located at the top of a mountain just a few hundred feet apart so effectively, it appears they are at the same spot from my house and I think I have direct line of sight of them, although they are very low on the horizon.
One of the transmitters is owned by Idaho Public TV and it is a shorter transmitter and broadcasts a weaker signal than the other larger transmitter. For some reason, I get the Idaho Public TV channels (K44KK-D)perfectly fine regardless of where I put my antenna but I can't get the channels from the other transmitter at all. I'm only trying to get the channels at 160 degrees azimuth.
Here is the TV Fool report for my location.
http://www.tvfool.com/?option=com_wr...46aebb6da66cd4
I'm using a CM4228HD antenna without any mods and it's sitting outside about 15 feet above ground and slightly below the peaks of neighbouring houses. I have ~25 feet of good quality coax connecting the antenna to my TV with no splitters, amplifiers, etc.
When I scan for channels, I always get the K44KK-D channels but no other ones. I can even tune my TV to the real broadcast channels and again I get K44KK-D and nothing else.
I can't figure out why I can't get the other channels (e.g. K50GL-D) considering they are broadcast using more power and their transmitter is taller. Does anyone have any suggestions what might be wrong?
bsp is offline   Reply With Quote
