Old 16-Aug-2013, 1:59 PM   #3
Billiam
You'll need a rotor if you want to pick up Ch. 3 and Ch. 8. I doubt a fixed antenna at 300 degrees will give you reception of these two channels. I think you'll need a HBU 55 if you want WCTX TV. I used the HBU55 at my former home and had signals on UHF as weak as that one and they came in fine without any amplification. In this case, since you have some weak fringe signals best to go with the larger antenna.
