Old 16-Aug-2013, 1:08 AM   #3
Install a Antenna Craft HD850 All Channel antenna aimed at about 251 degree magnetic compass direction.
Use a Old School magnetic compass.
________________
Disconnect and Remove ALL power injectors.
Disconnect and Remove ALL amplifiers.
Disconnect and Remove ALL amplifier power supplies.
________________
For 3 Tv's connected use a simple common 3 way splitter.
For 4 Tv's connected use a simple common 4 way splitter.
_________________
To keep Weather/Water out of outside coax and connections.
Use NEW RG-6 coax that has the Compression type connectors on the ends of the coax , not the old crimp type connectors.
To make double sure that weather/water does not get into outside connections and coax and matching transformer (balun).
Wrap with , http://www.coaxseal.com.
_______________
Here are places to buy antennas and etc. .
http://www.solidsignal.com.
http://www.amazon.com.
http://www.antennacraft.net.
