Old 15-Aug-2013, 12:44 PM   #9
No static at all
No static at all's Avatar
Originally Posted by Mike38261 View Post
From your experience, are the tuners built into the televisions more sensitive/ better quality than the converter boxes?
It's a toss-up as some models do perform a bit better than others, so really hard to say one way or another. A good antenna system & conservative amplification (if needed) should help overcome any inherent weaknesses in a TV's tuner.
Not being able to manually add channels is an issue with many TV's & can be a problem if using a rotor. It's also nice to be able to manually add channels when real/virtual channel conflicts are present.
