Interesting about the thrust bearing, I actually have an extra rotor motor that I believe will work with the 9521's digital controller, I may try it w/out it first and if it fails, I will have a backup. I have a feeling I have only just started experimenting with equipment and hardware anyways...
One more question for you guys, as I mentioned earlier I have an older HDTV without a built in digital tuner, I'm using a cheap RCA converter box for now until buying a new TV this fall. From your experience, are the tuners built into the televisions more sensitive/ better quality than the converter boxes? Or could I expect to lose a few of the fringe channels when switching to a built in tuner?
