Old 15-Aug-2013, 12:11 PM   #1
macmansc
Antenna Choice for Rural Area between 2 cities
Here's my location.http://www.tvfool.com/?option=com_wr...46aefa8a8728e8
I had purchased this antenna a little over 2 years ago. http://www.amazon.com/Sewell-Direct-...direct+antenna
I got about 18 channels with it, and it picked up well enough never to need the rotator. However, it's approaching my second anniversary of cutting the cord and I need an upgrade (mainly because the amp went out).
Which should do the trick the ChannelMaster 4228HD or Clearstream C4. Should I use the CM7777 preamp with each? I put a Clearstream C2 with no amp, but it didn't fair too well.
This will be an attic install.
macmansc is offline   Reply With Quote
