Old 14-Aug-2013, 1:10 PM   #7
No static at all
No static at all's Avatar
Originally Posted by Mike38261 View Post
I do have a 9521a that I have not installed yet (waiting on permanent mast) and I was worried about the immense size of the 3020 causing rotor failure. I will definitely be purchasing the thrust bearing.
You DO NOT need a thrust bearing. Keep the mast above the rotor as short as possible if using the 3020. (6 inches or so) Having too mast above the rotor is the real deal breaker with light duty rotors.
My 9521 lasted many years (still works, but not using it) even though I used too much mast above the rotor for over a year as seen in this photo.
