Old 14-Aug-2013, 12:01 AM   #6
Just to pile on a bit...
The strong local signals should be powerful enough to drive several TVs without any amplifier... You need to remove all parts of it to confirm the basic function of the antenna.
As teleview has suggested, the best way to test the antenna, is to run a known good cable from the antenna, directly to a known good TV.
