Old 13-Aug-2013, 10:06 PM   #5
-->YES you ave a Excelent reception location.<--
_________________________________
So what is the make and model number of the antenna.
It looks like a Channel Master CM4228HD UHF/VHF antenna that is desinged to receive UHF channels 14 thru 51 and VHF high band channels 7 thru 13.
YES you have a Excelent reception location.
The transmission/reception in the Green and Yellow reception zones are Strong Signal Strength and are easy to receive.
______________
The reception of the VHF high band channels 7 thru 13 will be received even with a antenna that is designed for UHF reception , Reason: the Tv transmissions are Very Strong at your location.
Examples ,
WJLA VHF high band channel 7.
WUSA VHFhigh band channel 9.
___________________________________
Aim the antenna at about 65 degree magnetic compass direction.
Water damage of outside connections and coax is the most likely cause of reception that gets less and less as time goes by.
As a ->Test<- to prove reception.
Disconnect and remove ALL parts of amplifier , disconnect and remove the amplifier unit , disconnect and remove the power injector , disconnect and remove the power supply.
Connect a ->NEW<- continues length of coax that has the compression type connectors on the ends of the coax , not the old crimp type connectors.
Run the NEW continues length of coax through a open door or window direct to 1 Tv.
No couplers , No splitters , No ground couples , No nothing.
It is the , Antenna , the NEW coax , the Tv.
Digital tuners can develop -Digital Glitches- that are not cleared out with simple channel scans.
Do Double Rescan , http://www.dtv.gov/rescan.html.
________________________________________
If reception still has problems , then the connection , transformer/balun , of the antenna can be bad from water damage.
->ALL<-> outside connections are suspect of being bad.
And All other connections and coax is/are suspect of being bad through out the whole system , both inside and outside of the building.
Water will get into coax and damage the coax.
