Old 13-Aug-2013, 8:47 PM   #2
No static at all
No static at all's Avatar
Unfortunately the antenna choice is not ideal, but may work if only DC stations are needed. Did 7 & 9 ever come in well?
The biggest issue though is likely the amp overloading from channel 24 in Merrifield. (Ouch) Have you ever tried completely bypassing the amp & connect the antenna directly to 1 TV?
Reliable reception of both DC & Baltimore are possible at your location if desired, but not sure if Baltimore is on your must have list?
Let us know your thoughts.
