Old 13-Aug-2013, 5:25 AM   #2
Oak leafs will burry a 'leaf'
Getting over or around the trees will do more for reliable reception than any other single component choice. Here in the Pacific NW, I'm working on mounting in a Western Red Cedar at about 90' AGL... and I'm still no over the 120' tall Douglas Fir trees in the neighborhood.
I've also considered first trying one of the 'paper thin' square style indoor window antennas just to see what kind of results I'd get. Would I have any chance at getting the yellow shaded channels with one of these or would this just be a waste of time?
The UHF only capability together with little true antenna gain makes the 'leaf' style antenna one of the lowest on my list in your situation. I doubt you would get reliable reception of real channels 8, 9 or 11.
At minimum, I would like to receive WCSH and all of the stronger signals so that I would get the major networks: ABC, NBC, CBS & FOX.
I think your best opportunity for that is to point an Antennas Direct 91XG at WHDH, real CH-42, azimuth 207° magnetic. Equip the antenna with an Antennas Direct PA-18 preamplifier.
To add WCSH to the lineup will require that you rotate the antenna (which is a source of conflict in multi-TV / viewer homes) or add a second 91XG dedicated to azimuth 31° magnetic. (Then you would need to consider your options on how to combine or switch antennas... http://forum.tvfool.com/showthread.php?t=820 http://forum.tvfool.com/showthread.php?t=2882)
FWIW: An Antennacraft Y5713 pointed at azimuth 260° magnetic would add WENH & WMUR to your line-up. Combining these these VHF signals with the UHF signals from the 91XG is done easily and reliably with an inexpensive UVSJ. http://www.solidsignal.com/pview.asp...Combiners&sku=
