[QUOTE=GroundUrMast;37631]You have a very good shot at virtually all the available channels in the greater Seattle area. Given the terrain, you're in an enviable position.
You got that right (about terrain)!! I'm adjacent to Paine Field -- my house elevation is about 600' MSL.
Hey, GroundUrMast, since you're local -- I see that the installer forum is pretty dead. Have you any recommendations for a competent installer in our area? You may reply by PM if there's some forum restriction on recommending specific vendors/businesses.
Anyway, thanks so much for your prompt reply!! I'll purchase the recommended antenna right away, since I'd like to have everything in place and tested prior to the cutoff date.
Susan
Don't put Descartes before des horse
