Old 12-Aug-2013, 10:07 PM   #1
Av8rix
Av8rix's Avatar
Cutting cord in Puget Sound area
Hi, I’m a n00b here. I will be cancelling satellite in the middle of September and would like to prepare for that now. I’ll be purchasing a rooftop antenna, as one station that I need to receive is in the “yellow” range and I have a relatively low-pitch roof with no good attic site in which to place an antenna. To control recording, streaming, etc, I’ll be building a dedicated home theater PC.
My TV is a Panasonic TH-42PX75U.
Here’s my signal report: http://www.tvfool.com/?option=com_wr...46aea09421524e
I have three questions:
1. The only VHF station I really need is the PBS, which is relatively high frequency (channel 9). Will I need a UHF/VHF antenna or am I likely to have satisfactory reception with a UHF-only antenna?
2. I live alone and have only one TV set, no need for a splitter. Also, house is only one-story and antenna will be positioned on roof within a <25’ cable run of the TV. Will I require a preamp?
3. Is a multidirectional antenna generally preferable or is it more desirable to have a directional antenna mounted on a remote-controlled rotor?
Thanks in advance for any help you might offer with antenna selection based upon the above information.
Susan
Don't put Descartes before des horse
Av8rix is offline   Reply With Quote
