Old 12-Aug-2013, 8:47 PM   #1
Chundo
Antenna Suggestions - Southeast NH
Hello - I'm looking for some antenna suggestions to pick up the major networks around my area. Based on my location, there are some desirable transmissions just under 70 miles away at 192 & 193 degrees. At minimum, I would like to receive WCSH and all of the stronger signals so that I would get the major networks: ABC, NBC, CBS & FOX.
Here's my signal report @ 20':
http://www.tvfool.com/?option=com_wr...46ae8f190545d5
My location is slightly elevated with relatively flat surrounding terrain, but the property is also surrounded by some very tall & leafy oak trees. I'm figuring an outdoor roof mounted antenna will be needed to have any chance at the far away signals. I'm mostly wondering if there are any simple (non-rotor & relatively small) roof mounted antenna options that would give me good results?
I've also considered first trying one of the 'paper thin' square style indoor window antennas just to see what kind of results I'd get. Would I have any chance at getting the yellow shaded channels with one of these or would this just be a waste of time?
Thanks in advance for your suggestions - much appreciated!
Chundo is offline   Reply With Quote
