Old 12-Aug-2013, 8:21 PM   #4
The Main group of Digital Broadcast Tv stations/transmitters are to the , North West.
Above the Peak Of The Roof in such a manner that roof and house are not impeding and blocking reception to the , North West , South West.
Install a Channel Master CM4228HD antenna aimed at about 312 degree magnetic compass direction.
The signal strengths in the Green reception zone of the tvfool report are medium strong.
A antenna system amplifier will most likely not be required.
A antenna rotator will not be required.
________________________________________________
For 2 Tv's connected uae a simple common 2 way splitter.
Use the , ronard(911) , 5 foot antenna mount.
http://www.ronard.com/Tripods%200703/4712.html.
10 foot antenna mount.
Measure the chimney and use a , ronard(2212) , ronard(2218) , ronard(2224).
Buy the ronard antenna mounts at solidsignal or buy from ronard.
http://www.solidsignal.com.
http://www.amazon.com.
You did not indacate the directions of the trees.
As always , trees and tree leaves , plants and plant leaves , have a Negative effect on , OTA=Over The Air , Broadcast Tv reception with an Tv antenna and so do buildings including your own roof and building and other obstructions.
The Best Practice is to install the CM4228HD antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
The Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital tv's will Automatic channel scan for cable tv channels.
Go into the Tv Setup Menu and select , 'Air Channels' ~ 'Antenna Channels'.
Scan for channels.
The Cable Tv System , be it , cable tv , cable internet , cable phone , or any any other type or kind of cable service Can Not be connected to the antenna system.
Yes the coaxes that are in/on the building can be used for the antenna system.
Any type or kind of cale service Must Be on Seperate Coax.
Do Not connected antenna system and cable system on to same coax/s.
