Old 12-Aug-2013, 10:11 AM   #12
StephanieS
PPS: K40EE, which is the analog translator to KXLY at 156 degrees, I do see it off the side. Picture locks and it flickers in and out of color with occasional audio. Perhaps Teleview's suggestion is the best course, pointing right at KLEW and seeing if the ANT751 by itself pulls it in. I don't want to do a rotor solution. If I went dedicated antenna for KLEW, I'd need to a coupler. It's just a question now if the db loss will deal break it... I'd hate to put a preamp in to overload. Although, I did see, Radio Shack sells a preamp attenuator that allows you to dial it down to a sweet spot if you are in an overload situation.
