Old 11-Aug-2013, 9:08 PM   #3
TomT
I would like to get only 1 antenna and if necessary I will use only 1 TV. How high should I mount the antenna over the chimney and what kind of brackets do you use for this? My chimney is about 25 feet above ground level. Can I put two antennas on one mast to get better reception or is it going to be just another cost? I will have to get help so I need to figure it out before hand as I will have little ability for adjustment after the big ladder is gone. With those big aluminum antennas you suggested do you need to do anything to add signal or is it just another frizz?
Thanks for your reply.
TomT is offline   Reply With Quote
