Old 11-Aug-2013, 7:49 PM   #4
The amplifier's job is to overcome losses in cable and splitters. To do that job requires that the amplifier be located upstream of the loss... It can only 'push' signal down the line. An amplifier can not 'pull' signal from the coax, antenna or the air.
So, one amplifier close to the antenna will out-perform one at each TV.
