What Antenna should I use
Ok so I moved to new location. To be more exact my grandma's old farm. There's already an antenna but I think it's an old one before the digital switch so it's better at getting analog signals even though we don't do that anymore here.
Anyways on a Normal day I get WEUX which is a fox station out of Eau Claire, WI. I get the ME TV station attached to it as well.
On some days I get 3 PBS stations and 3 ABC stations(actually one is a CW and another is a movie channel) called WQOW but often those 2 channels come in an out regularly which is frustrating.
Now I checked my coordinates on the realistic map you guys have it says I'm supposed to get WEAU which is an NBC station out of Eau Claire, WI. I have yet to get the channel in. Since the old antenna is an analog one and has a 60 mile range, I am wondering if I should get an antenna with a stronger range. So I want to know what would be a good antenna to use to get these channels in.
If you need any more information, I'll be happy to provide it but after checking on the map I am confident in what channels I should be getting. I just need a new a much better antenna with more than a 60 mile range.
