Old 11-Aug-2013, 7:05 AM   #2
It's hard to tell if the antenna has any UHF capability, the photo does not show the entire antenna. What I see is a worn & broken VHF log periodic dipole array (LPDA) which may or may not have a UHF section on the front end of it. If present, the UHF section would be a group of short elements and there may or may not be a corner reflector assembly at the rear of the UHF section.
You need an antenna that supports both UHF and VHF reception.
The signal levels shown on your report for WBIQ and the six just above it on the list will need a high gain antenna... and it needs to be outside, clear of obstructions. Reliable reception from inside an attic is not likely.
I would opt for a Winegard HD7084.
