Old 11-Aug-2013, 3:11 AM   #8
If you have room in the attic, the Antennacraft Y10713 is not overkill. The shorter Y5713 would be fine outside in the clear and may be OK in the attic.
You'll also need a UVSJ to combine the UHF and VHF signals into a single coax.
http://www.antennacraft.net/Antennas/AntennasVHF.html
http://www.solidsignal.com/pview.asp...nna-%28uvsj%29
