Old 11-Aug-2013, 1:14 AM   #7
markieb
The results are in!!
Today I installed the antenna (HD7697P) and pre-amp (HDP-269). after assembling the antenna, I set it on a table outside near where I was going to install it, pointed it at about 340 as GroundUrMast suggested. I then hooked it up to a TV inside, scanned for channels and got 46 CHANNELS!!! I was pretty happy with that! I then installed a mast about 16' high, put the antenna and pre-amp on, aimed it at the same place....and... 57 CHANNELS!! Using my analysis in my original post, I get ALL the stations and sub-channels from the top green (WBBH-DT 15 (20.1)), down to the first one in red (WLWN-LD 39), except W17CK 17 and WTPH-LP 14 I can't find any programming info on either one, so I'm not concerned about them.
I wish to thank GroundUrMast for the equipment suggestions they turned out to be spot on. Thank You VERY much!
Tomorrow I'll pretty-up the installation and hookup the other 2 TVs ... Then SNIP, SNIP goes DishNetwork!
markieb is offline   Reply With Quote
