Old 10-Aug-2013, 7:02 PM   #2
For reception of , Many , many , many , many , many , many , many , many , . Canada and USA , Digital Broadcast Tv stations/channels.
Install a Winegard HD7698P antenna above the peak of the roof in such a manner that the roof and building are not impeding and blocking reception in the directions of , East , South East , South , South West , West.
Aim the HD7698P antenna at about 160 degree magnetic compass direction.
_____________
Measure the chimney and use a , ronard(2212) , ronard(2218) , ronard(2224) .
_____
http://www.saveandreplay.com.
http://www.trentondistributors.com.
http://www.amazon.ca.
http://www.amazon.com.
http://www.ronard.com.
_________________________
Install a Winegard , LNA-100 'Boost' , antenna system amplifier.
As always , trees and tree leaves , plants and plant leaves , have a Negative effect ,
multi-path reflections of Tv signals.
absorbing Tv signals.
blocking Tv signals.
and so do buildings including your own roof and building and other obstructions in directions of reception.
The Best Practice is to install the HD7698P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
___________
The Tv/s Must CHannel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital tv's will Automatic channel scan for cable tv channels.
Go into the Tv Setup Menu and select , 'Air Channels' ~ 'Antenna Channels'.
Scan for channels.
