Old 9-Aug-2013, 12:35 AM   #10
Jeremiah
If you prove the need for amplification, and are mounting everything indoors, the Channel Master CM-3410 is a very good distribution amplifier that is hard to overload and also has decent noise/distortion performance. It can be powered remotely if needed. http://www.amazon.com/Channel-Master.../dp/B001FY0B90, http://www.amazon.com/PCT-Inserter-M.../dp/B005Y12UH6
It has now been several months, and I do have the antenna installed. Well, it appears I will need this amplifier after all. Two questions, though: What is that PCT Inserter that you linked to and what is its function? And, since I am splitting the signal, will that 1 port amp work or do I need one with two ports? I guess what I am asking is if the signal has to be split at the amp itself, or if I can split the signal coming out of the amp with a regular 2-way splitter.
Thanks again.
Jeremiah is offline   Reply With Quote
