Teleview is correct, it will be helpful to know what type antenna you're using. Even if we don't know the brand or model, an accurate description will help us understand if it supports both UHF and VHF reception, which you need.
Can you describe the materials used in your roof and attic construction? Are there heating/cooling ducts or other metal near the antenna?
Have you considered 'testing' the reception with an antenna outside?
