San Deigo is often a two antenna market
That you are getting the UHF signals you want is great... Your TV Fool report suggests they would be challenging when forced to use an east facing window.
Can you consider using an outdoor antenna (mounted indoors or on a patio) in addition to your existing antenna? I'm thinking of the Antennacraft Y5713 and a UVSJ, Radio Shack Catalog #: 15-2586 or Pico Macom - UVSJ. You would connect the Y5713 to the VHF port of the UVSJ and the output of your existing antenna would connect to the UHF port.
