Old 8-Aug-2013, 9:30 PM   #4
As I understand it you are saying that the best place/location for reception is the chimney.
The reason I recommend the ronard 4424 is because it holds the antenna mast further away from the chimney so the HD850 All channel antenna can be mounted above the chimney.
_______________________________
Yes you can also Test reception with the CM2016 and a different chimney mount then the ronard 4424.
