Old 8-Aug-2013, 6:55 PM   #3
Above the Peak of the Roof in such a manner that the roof and building are not impeding and blocking reception in the direction of , South East.
Install a Channel Master CM4228HD antenna aimed at about 130 degree magnetic compass direction.
A Winegard DS3000 , J pole type antenna mount works well with the CM4228HD antenna.
Here are some other antenna mounts.
Measure the chimney and use a , ronard(2212) , ronard(2218) , ronard(2224) , .
Buy the ronard antenna mounts at solidsignal by typing , ronard(x) , in the solidsignal search box or buy from ronard.
__________
Install a Channel Master CM7778 preamplifier.
_________________________
For 4 Tv's connected use a , HFS-4D , 4 way splitter.
Buy the HFS splitters at , http://www.solidsignal.com or http://www.hollandelectronics.com.
_______________________________
http://www.solidsignal.com.
http://www.amazon.com.
http://www.channelmasterstore.com.
http://www.ronard.com.
____________________________________
As always , trees and tree leaves , plants and plant leaves , have a Negative effect ,
Multi-path/reflections.
Absorbing the Tv signals.
Blocking the Tv signals.
and so do buildings including your own roof and house and other obstructions.
The Best Practice is to install the CM4228HD antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception includung your own roof and house.
_____________
The Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some Digital Tv's will Automatic channel scan for cable tv channels.
Go into the Tv Setup Menu and select , 'Air Channels' ~ 'Antenna Channels.
Scan for channels.
___
The Tv Must Channel Scan for the , ATSC , aka , 8VSB , Digital Broadcast Tv channels.
The Current Broadcast Tv channels in , USA , Canada , Mexico , are.
UHF band channels 14 thru 51.
The Current receivable broadcast Tv channels at your location are UHF channels.
Last edited by teleview; 9-Aug-2013 at 6:38 PM. Reason: Clarify information and typos.
