Old 7-Aug-2013, 11:48 PM   #2
As always , combining dissimler antennas with a reversed splitter in a random way , produces bad reception.
Connecting antenna system amplifiers / distribution amplifiers and amplified antennas in a random way produces bad reception.
Disconnect and Remove All of the antennas and amplifiers.
_____________
Recommend install a , --> Antennas Direct - Clear Stream 2 Complete Uhf/Vhf antenna <-- , in/at the window aimed at about 72 degree magnetic compass direction.
CS2 Complete Uhf/Vhf antenna at Amazon. C2-V-CJM .
______________________
For 3 Tv's connected use a simple common 3 way splitter.
For 4 Tv's connected use a simple common 4 way splitter.
Test reception Without a antenna system amplifier.
If a antenna system amplifier is required , use a , Winegard LNA-100 'Boost' antenna system amplifier.
_________________________________________
http://www.solidsignal.com.
http://www.amazon.com.
http://www.antennasdirect.com.
Last edited by teleview; 8-Aug-2013 at 9:58 PM. Reason: Clarify information and typos.
