not sure of your actual location and i know someone will come on here and say "well every location is different"
but i have a small passive 2 bay antenna and get all Charlotte stations to 3 tv's all over the house all passive mounted on my back deck pointed straight at some trees ...
so just my best guess would be you'll be fine in the attic and your tvfool looks better than mine at your location ...
if you want winston/hickory/ etc you'll need to go on the roof and point in that direction you'll probably pick up all clt regardless of where you point your antenna ...
just an fyi your hoa can't make you not put up an antenna against the law ... but if you have a back yard you can usually get away with putting it on the back side of the roof and just having it peak over we have a few of these in the neighborhood and its barely visible from street
actually your biggest challenge is signal from so many directions and an antenna that is very directive ...
my plan was to do a roof mount but after i got everything i wanted on my sat dish mount on the back deck i just figured i'd be done.
good luck !!
