A better antenna would be my next move. There is nothing wrong with the amp you have. It handles strong signals remarkably well & has relatively low noise.
I would never suggest the HDP-269 unless used with an attic/indoor antenna. The HDP-269 is too sensitive to static buildup & more prone to failure than any other amp from my experience/research. The HDP is over-rated/over-recommended & there are many better choices for strong signal environments.
